Discussion topic: Error MR102
This message was authored by: FRANCES18
Error MR102
What is error MR102
Re: Error MR102
@FRANCES18 wrote:
What is error MR102
@FRANCES18 normally you see this if the mini box isnt connecting to the main box
Have you tried rebooting your main Q box ie
then
rebooting the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Error MR102
@FRANCES18 wrote:
What is error MR102
Try a Network reset on the mini @FRANCES18
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
