Discussion topic: Swapped Sky Q Box and some sub channels I cant record
This message was authored by: Babypink2807
My previous Sky Q box stopped working.  Was sent a new one today, what a palaver it was to get working.
I have Basic package for Sky and could watch ITV Be HD , which I still can.  However when I set to record it states I do not have a subscription.   All that has happened is I changed the box.  I could record last week but now today I can't
Sky is hopeless trying to get through to them, auto attendant says it will send a text, what use is that!  Then it does send and it doesn't work then it does not send.  All day messing with this and no further forward.  Just want to speak to a human being.
Re: Swapped Sky Q Box and some sub channels I cant record
@Babypink2807 a couple of things to try
Have you tried rebooting your main Q box ie
if that doesnt work
You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
You did swap over your viewing card?
