Discussion topic: Sky Q no Internet connection with Sky router
Message posted on 12 May 2025 05:44 PM
Sky Q showing no Internet connection
Sky router/ Sky broadband
Gone thru reset on many occasions - box and router but still no connection
Sky broadband working OK elsewhere
Sky satellite connection OK
Message posted on 12 May 2025 06:04 PM - last edited: 12 May 2025 06:05 PM
							Re: Sky Q no Internet connection with Sky router
Hi @GordonN
if this is with the New Sky Max router then this needs connecting to the main Q box as if it is a 3rd party router. This means that you need to use the router SSID and password to connect it to the router 2.4 Ghz band.
If it is not a Sky Max router then you should be able to connect it by WPS.
However the Q box needs to be in WiFi range of the router.
Message posted on 12 May 2025 07:41 PM
Thanks for comments. Not sure what you mean by the New Sky Max router? I've had the router for a few years and it's suddenly stopped working. Tried the reset function many times without success. Broadband service to other devices all OK.
