Discussion topic: Error MR102
Message posted on 18 Aug 2023 08:32 AM - last edited: 18 Aug 2023 08:52 AM
Error MR102
My Q remote box has stopped connecting to the main box (approx 20 feet away)
So please don't suggest a signal booster
This is the second evening that this has happened
When I follow the on-screen fix instructions - it tells me to reboot the router
Which is not going to help - my ISP is NOT Sky - so the remote box is connected to the main box
yesterday - I managed to find "reactivate connection" - but that failed to help
I am unable to even escape from the error message to enter settings or anything else
Could someone please provide simple step by step instructions to restore the remote box ?
Failing that - I assume that since my set up is only 6 months old - Sky will send an engineer out free to fix it ?
I am a diamond VIP
thank you
Message posted on 18 Aug 2023 10:35 AM
Re: Error MR102
I have finally managed to fix the MR102 issue
Could it be linked to us turning the Remote box OFF AT THE WALL every night ?
Message posted on 18 Aug 2023 10:39 AM - last edited: 18 Aug 2023 10:42 AM
Re: Error MR102
@Anonymous wrote:Could it be linked to us turning the Remote box OFF AT THE WALL every night ?
Probably, whatever a 'remote box' is? The mini box itself? (They burn next to no electricity - for me a TV, soundbar and mini on standby consumes 11W)
I turn mine off every night but is connected with ethernet - no issues other than a few minutes to boot and connect.
Message posted on 18 Aug 2023 10:41 AM
Re: Error MR102
Hi @Anonymous
Certainly Q boxes are not intended to be powered off at mains on a daily basis.
They should be kept in Standby when not in use.
Power requirements are minimal if put in Eco standby.
https://www.sky.com/help/articles/using-the-standby-settings
Best to have all Q boxes in the same standby mode.
Message posted on 18 Aug 2023 11:00 AM
Re: Error MR102
It does get "warm" and the OH has fire concerns !
Message posted on 18 Aug 2023 11:09 AM
Re: Error MR102
@Anonymous
All Sky boxes get warm and are made from materials to deal with it. You should make sure the boxes are in a well ventilated position and you should always be able to rest your hand down on the top.
Message posted on 20 Aug 2023 08:02 AM - last edited: 20 Aug 2023 08:24 AM
Re: Error MR102
Unfortunately the mini box appears to need resetting every time that it is booted up !
Yesterday evening, it did it again
The main box (less than 20 feet away from the mini box) was used to reactivate - the connection at the minibox - but that failed to help.
The main box has a tick by "watch on sky minibox" under settings
The satellite signal has a tick by it
We tried the WPS button on the main box - this told us that it was connected - but it still told us differently at the minibox
Eventually - I tried the NEW CONNECTION option on the Q & A that keeps on appearing and that worked - but we shouldn't have to manually reconnect every time that we switch on........
Is there a simple step by step reset guide to fix MR 102 errors ?
unbeliveably - sky's answer is to "close the doors"
Stress the Sky Q system
Your connectivity problem should now be fixed and you should be connected. You can check this by following our steps below.
Make sure everything is now working as expected by ‘stressing’ the Sky Q system:
- Close all the doors in the house
- On a Sky Q Mini box, start watching any HD channel (such as Sky Sports HD)
- On the Sky Q 1TB/2TB box, start downloading any HD content
- If there are any devices available, start streaming content from the Sky Q box
- Leave everything running for a minute or so.
If you're still seeing issues with your connection please go back and try the steps again.
Message posted on 20 Aug 2023 08:46 AM
Re: Error MR102
Hi @Anonymous Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the same with any Mini boxes?
Message posted on 20 Aug 2023 09:08 AM - last edited: 20 Aug 2023 09:16 AM
Re: Error MR102
@Quoman7The minibox goes off every night anyway
it seems that sky flowcharts - https://www.sky.com/help/articles/setting-up-sky-q-mini-box - are not designed for anything other than Sky ISP (ie Signal coming from router rather than main box)
When I go through the different steps - it works - but on rebooting the minibox - it does not reconnect - it loses the connection permanantly and I have to go through the process again...
Message posted on 20 Aug 2023 01:53 PM
Re: Error MR102
"Priority Customers" have arranged for an engineer visit to sort it on Thursday
Presumably free - since the set up is only 6 months old ?
Message posted on 20 Aug 2023 02:12 PM - last edited: 20 Aug 2023 02:13 PM
Re: Error MR102
As all Equipment belongs to Sky; Engineer visits to sort out Q issues are always free @Anonymous
Unless of course of course you request a special weekend visit
Message posted on 20 Aug 2023 02:17 PM
Re: Error MR102
@Anonymous yep therte will be no charge for the visit as Sky own the equipment it is up to Sky to maintain it
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 20 Aug 2023 04:44 PM
Re: Error MR102
Message posted on 20 Aug 2023 04:54 PM - last edited: 20 Aug 2023 04:55 PM
Re: Error MR102
