Discussion topic: Eratic response on Mini box from the remote
This message was authored by: Wayne92
I have two mini box's the  one upstairs is fine but the one in my kitchen is playing up when I select the menu it's freezing on menu all that happens when I press the remote is the screen flickers I have tried turning off and resetting but when it comes back on it may work temporarily but then if you go to the menu again it does the same , I have tried a different remote but it just does the same .
Re: Eratic response on Mini box from the remote
@Wayne92 Have you tried rebooting your main Q box ie
then rebooting your mini box in the kitchen
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Wayne92
Thank you I tried that but still
the same , however whilst doing it I think I may have found the issue . I think it may be the remote what threw me was when I brought the remote from the main box it would work then I tried the original remote still wouldn't work made the screen flash but nothing else then when I went back to the main box remote it did the same just flashed the screen so switched off started again and so long as I don't use the original remote the main box remote doesn't falter if that makes sense . Fingers crossed problem solved only time will tell , Thanks for your help 👍
