Discussion topic: Engineer connected to old wires
This message was authored by: CrazzyCritter
Message posted on 11 Jul 2024 03:47 PM
Hello,
An engineer has been to 'move' is today and connected to the wires that already existed, should he have provided new wires and drilled new holes in to the house?
Also, will a connector for the wires cause a bad connection?
Thanks,
Find out more
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Please note: I am just a sky customer not a employee - posts from sky employees (aka community team) are clearly marked as suchmy setup: Samsung 5 series 32inc tv | sky +hd box | variety, SKY & TNT sports,sky cinema | Netflix and prime video Please note: I only provide help on the main forums and not via PM ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ if this post has helped please give it a like ~ if this post has solved your question/query please mark it as the answer in order to help others
Message posted on 11 Jul 2024 03:50 PM - last edited: 11 Jul 2024 03:53 PM
Re: Engineer connected to old wires
@CrazzyCritter No they will only replace if it's deemed necessary to do so
the only thing they will change is the LNB on the end of the dish if you are switching from sky plus
