Discussion topic: Dropping Network Connection
Message posted on 29 Aug 2025 06:24 PM
When watching Apps - my Sky Q box can drop the Sky WiFi connection every five minutes or so. While at the same time, in the same room and on the same WiFi connection, I can watch the same Apps on my iPad or Fire TV with no issues. I've tried the disconnect/reconnect router, QBox stuff and the issue remains. Internet is also ok on phones and PC. Starting to get extremely frustrated with Sky and will most likely leave if the issue cant be resolved
Message posted on 29 Aug 2025 08:02 PM
Re: Dropping Network Connection
Use powerlines
Message posted on 29 Aug 2025 09:13 PM
Do you mean ethernet cable? My broadband is connected to sky box withban ethernet cable
Message posted on 29 Aug 2025 09:58 PM
@V,GILLETT wrote:Do you mean ethernet cable? My broadband is connected to sky box withban ethernet cable
?? You said it was dropping the wifi connection?
