Discussion topic: Downloads queued
Message posted on 10 Mar 2023 10:17 PM
Downloads queued
When I try to download a programme from the Sky app to my Sky Q box, it gets stuck in Queued and never downloads. I have tried the suggestions I've seen from others users with the same problem but nothing has worked - I have made sure I have plenty of disk space, I don't have anything else downloading or recording, I have restarted the box, and tried Pausing and re-starting the download, but it's still stuck. Any other suggestions?
Message posted on 10 Mar 2023 10:21 PM
Re: Downloads queued
Hi @Linsey+Jane
Check your Recordings - Most recent section and also the Deleted section in Manage for any failed recordings. Any you find want completely deleting from both sections.
Message posted on 10 Mar 2023 10:24 PM
Thanks - I've done that but no joy unfortunately.
Message posted on 10 Mar 2023 10:32 PM
Assuming you're meaning the Sky Go app? Have you tried reactivating this on Q?:
Hit Home > Settings > Status > Watch via Sky Go > Reactivate
Worth a try.
Good luck.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Message posted on 10 Mar 2023 10:34 PM
Hi @Linsey+Jane
Delete all the Queued downloads and then
Message posted on 10 Mar 2023 10:52 PM
I have done everything you suggested and then tried to download a programme again. This time it's stuck saying 'Downloading (0%)' instead of 'Queued', but still won't download.
Message posted on 13 Oct 2023 09:25 PM
@Linsey+Jane. I've been having this issue for months, maybe longer! It was on my to do list but I keep forgetting to contact SkyQ about it. It's started irking me now though as my box sets are falling behind on downloading and I'm constantly catching up to the last one downloaded and I have to go to 'manage', everything is queued and I have to manually 'start each download' to kick start it! Even then it only downloads the one I manually started, it just won't move down the queue! I've tried different techniques but to no avail. The other issue I get is that, on the rare occasion the next episode is downloaded, it often goes to 101% but isn't playable. I have to cancel the download (because it still wants to carry on over 101%), it then says it's failed, I then have to start again, from scratch with a new download because, despite saying it was 101%, and me deleting it, it doesn't show in recently deleted! It's a flipping joke! Sadly, nothing I've seen here has worked. xx
Edit: I have a temporary, very temporary, work around. It's tiresome but it works. If you as many episodes as you can, the first will say downloading and the rest will be queued. Go to manage>downloading, go to each queued episode and choose start downloading. When it gets to 4-7%, and without cancelling or deleting anything, choose another queued episode. If you get that far without your eyes 👀 bleeding 🩸, pause the list at the top of the list, then restart the queue. I have found that doing it this way actually works ... but as I said, it's temporary (& tedious) so Sky needs to have a fix, or a better solution!
Hope it helps.
Dawn xx
Message posted on 08 Nov 2024 01:34 PM
I have exactly the same problem as Dawn-and like her have tried every suggested fix, including the hidden 0.0.1 fix. Nothing works! Download of Day of. the Jackal is stuck at 86%...The Q on Sky Q box now simply flashes blue constantly. Time for a new Sky Q box...?
Message posted on 30 Jul 2025 08:52 PM
Have had the same. The reset seems to have worked but there are still problems where programmes that we have watched for years were "queued" have now disappeared and
Message posted on 30 Jul 2025 08:55 PM
.... have disappeared from the search function
Message posted on 30 Jul 2025 09:41 PM
@Invicta+Moto wrote:.... have disappeared from the search function
Are they still being broadcast?
Message posted on 30 Jul 2025 09:49 PM
That could be the orobkem now. Kids love Superman and Lois. Will see if that one is available.
Bookish. Current series. Episodes 1-4 disappeared. Episode 1 was queued.....
Message posted on 30 Jul 2025 10:44 PM
Rebooted the Q ox by simply switching off and on.
Checked Internet connected. Bookish turned up in full in search.
