2
This discussion topic has been answered Discussion topic: Downloading
This message was authored by: Charley59
Downloading
Everything I try to download is queuing series link is working fine,  but I've got loads of programs in a queue with nothing happening.
This message was authored by: Laing1 Answer
Re: Downloading
@Charley59 check for any download that has failed and delete it then delete it from the deleted section if you cannot find any failed download in th recording check in the deleted section
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Downloading
Avatar for Charley59
Re: Downloading
Thanks for advice, happy to say it worked.
