Discussion topic: Downloading on sky q
Message posted on 20 Aug 2025 10:57 PM
Today my sky q has stopped downloading. Will record and play fine. When trying to download only reaches 1%. Have rebooted. Reset. Etc.
Message posted on 21 Aug 2025 05:31 AM
Re: Downloading on sky q
Try clearing the download queue completely including from the deleted section of Manage then trying again.
Message posted on 21 Aug 2025 07:51 AM
Yes tried that. Still no luck.
Message posted on 21 Aug 2025 07:55 AM
Try rebooting your broadband then rebooting your Sky Q box…
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 21 Aug 2025 11:09 AM
Unfortunately didn't work either.
