Discussion topic: 2 sky mini boxes not working saying subscription
This message was authored by: Rob271089
I have to sky q mini boxes and they are both showing the same fault
' please check your subscription entitles you tongue this channel
Re: 2 sky mini boxes not working saying subscription
@Rob271089
What channel(s) is this?
Avatar for Rob271089
This is for all channels on both sky q mini boxes
@Rob271089
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with the mini boxes -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
