Discussion topic: Downloading from u & yesterday
Message posted on 04 Feb 2026 07:56 PM
says i require a subscription ?
Message posted on 04 Feb 2026 08:14 PM
Re: Downloading from u & yesterday
hi @Jf30
Do you have the HD add on ?
If not it could be that the programme you are trying to download is in HD
if this is the case you, probably, just need to change your download preference to SD
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
Message posted on 05 Feb 2026 07:47 AM
I've changed to SD and it still gives the message, I can watch the channel and can record future programs but can't download older ones
Message posted on 05 Feb 2026 07:51 AM
hi @Jf30
In which case, I have escalated your post to a SKY support team, who, hopefully, will be in touch & might be able to assist
Please see this link re the escalation and what you might see:
Escalation Info
If you are using Safari I believe you must make sure that 'Hide IP address' is not checked in settings to be able to see it - if you have difficulty finding that setting then may be try accessing here with another browser
Message posted on 05 Feb 2026 08:43 AM
