9
This discussion topic has been answered Discussion topic: Sky Q Box loses broadband connection
This message was authored by: chris0x01
Hi.
My Sky Q box loses Internet connection every couple of hours. Pressing Home shows a message saying we're not connected to the Internet. Sometimes it restores after a couple of minutes, usually I need to turn off the mains power to fully reset the box. My box is plugged directly into my router via an ethernet cable so it's not a WIFI issue and all my other devices continue to access the Internet OK. I'm on Sky broadband. Anyone else had this issue?
This message was authored by: Chodley Answer
Re: Sky Q Box loses broadband connection
Have you disabled wifi on the box?
This message was authored by: Rob19661
Hi , Yes I'm having exactly the same issue. Tried everything to clear it. I get a message stating I might need a sky's booster. This Problem only started yesterday.
This message was authored by: Jemma88
Exactly the same issue, anyone fixed it yet?
Hi all,
I have just tried the below, as recommended by sky but it still has not solved the problem.
I'd suggest fully rebooting both the router and the Sky Q main box.
Unplug both of them, same time, from the wall for at least 30 seconds.
Plug back in the router only, get it up and running, and run a speed test on your mobile. Now plug back in the Sky Q box, go to settings, and reset the network settings section. Then scan for your router, add in your password, and hopefully, you're back up and running.
Avatar for chris0x01
Thanks for the suggestion. I've disabled WIFI in the service menu and so far (after 3 days) it's been OK. Fingers crossed that's sorted it.
This message was authored by: William5703
I have the same problem. If I reboot the router and the Sky Q box, it will reconnect.
About 10 minutes later, though, the Sky Q box advises that there is no internet connection.
My phone and others at home are all still connected,  so I am now at my wits end regarding this. It has been happening now for about 3 weeks.
This message was authored by: Teal22
Did you find a solution to this? My sky Q box is doing the same. We switched from BT to Sky broadband and it hasn't worked properly since! The internet connection drops every 15-20 mins, and I have to resent the box, pressing wps on the router etc.
I'd be grateful for an answer if you have one.
This message was authored by: Grizzo66
We are having this same issue, just upgraded to sky fibre and now the sky q box is losing connection constantly.. driving us nuts.
How do I get to speak to a human being at sky to get this fixed?
Hi. This is a complicated reply, but it did all work in the end. I went through the app to say I wanted to leave Sky because of all the problems but if they could get me an engineer visit that might help. They sent connected me with the engineers who brought out a new Sky q box, but also a Sky additional broadband booster for the tv. Apparently the signal split between the 2 boxes was too weak. This was before we switch to full fibre.
I also did cancel and start to switch to ee instead and got a fantastic deal with sky to stay as a result.  I hope this helps. It's impossible to get a phone number any other way.
