Discussion topic: Downloading HD
Message posted on 04 Jan 2024 08:47 PM
Downloading HD
I dont have HD when i try an watch shows i have to click on the SD to download the program but now I'm trying to do that and it's saying I don't have the right subscription any idea why I can't download? I can watch the channels but can't download any
Message posted on 04 Jan 2024 08:50 PM - last edited: 04 Jan 2024 08:50 PM
Re: Downloading HD
Hi @Danndans
If you do not have the Optional HD pack you need to change the Download to SD in All Formats (as HD is the default setting).
So that you do not need to do this every time it’s best to change your Download preference to SD in Home - Settings - Setup - Preferences.
This needs to be done on the main Q box.
Then if you want to download any HD content from free to air channels (BBCHD ,ITVHD etc) you can select HD in the All formats tab of the content . This will change the format for that particular download only but still leave your format to SD in preferences.
Message posted on 04 Jan 2024 09:03 PM
Re: Downloading HD
Hi thank you I've done that but now it's saying download failed 😢
Message posted on 04 Jan 2024 09:06 PM
Re: Downloading HD
Hi. @Danndans
Make sure that you delete any failed Downloads from your Recordings - Most recent section and also the Deleted section in Manage.
Then reboot your Q box and try the Download again.
Message posted on 05 Jan 2024 12:18 AM
Re: Downloading HD
Thanks so much I'll try that
