Discussion topic: Downgrading to Freesat from SKY Q problem
This message was authored by: nidash
I have sadly decided not to renew Sky Q this year, as i wanted to save some money and was not watching Sky channels - I was hoping I can just plug the sat cables into my freesat enabled LG TV and watch the usual free channels. To my disappointment i found my dish was upgraded with new LNB to have SKY Q now I cannot go back to using freesat on my TV.
I feel the engineer or sky installation team should inform new customers about this, or just install the hybrid LNB by default. Now I will have to change the LNB to HD one or buy a Freesat 4K box which is not cheap- I will have to foot anywhere between £120-£200 to get this done.
What are my chances if I ask SKY to reinstall the old LNB?
Re: Downgrading to Freesat from SKY Q problem
@nidash why not contact an independant installer to change the LNB back to a standard LNB hopefully that should be cheaper than a new box
Hi @nidash
Zero I'm afraid
Avatar for nidash
Yeah I think that's I would have to do, but slightly unhappy I was not told about it
Think I'd buy the 4k box. Bit more expensive but better end result and delta in cost probably not THAT much. Still save money vs Sky sub within 3-6 months probably.
