Discussion topic: downloading shows on Sky Q
Message posted on 04 Jan 2024 05:48 PM
Sometimes when I download shows or movies to my Sky Q box it will get to 100% then continue to "download" the show getting upto 150%+ downloaded. Why does my Sky Q box keep doing this?
Message posted on 04 Jan 2024 06:48 PM
Re: downloading shows on Sky Q
Hi @Trystin
Message posted on 04 Jan 2024 10:16 PM
Hi there, I tried this and now it won't let me download anything. Couldn't download the show I wanted to watch and I tried downloaded something else to see if it was a problem with that show or something else. But now I just get an error saying because of a technical issue it couldn't be downloaded right now.
Message posted on 04 Jan 2024 10:26 PM
Update: it's let me download the show is SD with no problem so that'll do for now.
Message posted on 04 Jan 2024 10:27 PM
Hi @Trystin
Can you make any new recordings from live channels or watch existing recordings.
Is this still shows errors you nave Hard drive issues.
If this is the case check through the following link.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Message posted on 04 Jan 2024 10:31 PM
It's allowing me to record live TV from HD channels and SD channels and I'm able to watch previous recordings and downloads.
