Discussion topic: Download to tablet not working
Message posted on 13 Jul 2023 06:15 PM
Going away and as normal I want to download a film to watch tonight. Each time I try with any film I get an unknown error saying it cannot download and to try later.
The tablet is on the same WiFi as Sky Q.
I have tried updating the app and charging the tablet more and no use.
Any ideas?
Message posted on 13 Jul 2023 06:21 PM - last edited: 13 Jul 2023 06:21 PM
Re: Download to tablet not working
Any ideas?
Hi @Tigger900
You need the Q Monthly Multiscreen to do this.
Do you have this?
Message posted on 13 Jul 2023 06:37 PM
Hi there,
is Q monthly something new? I've been able to download before and never heard of Q monthly. Where do I get that?
Message posted on 13 Jul 2023 06:47 PM
@Tigger900 wrote:
Hi there,
Hi @Tigger900
It's the Sky Q monthly Multiscreen subscription.
Message posted on 13 Jul 2023 10:32 PM
Thank you.
I have never had the Multiscreen subscription and have always been able to download films to take away. They stay on the tablet for a limited period and once started watching they go after 48hours.
I just don't know why the download is failing for an unknown reason?
Message posted on 13 Jul 2023 10:57 PM
@oldfella wrote:
@Tigger900 wrote:Going away and as normal I want to download a film to watch tonight. Each time I try with any film I get an unknown error saying it cannot download and to try later.
Any ideas?
Hi @Tigger900
Do you have this?
You don't need multiscreen to download content to a tablet or mobile phone, you only need it for Sky Go on Apple TV or consoles.
@Tigger900 - try logging out of the Sky Go app & logging back in or even deleting the app completely & reinstalling it.
Message posted on 14 Jul 2023 05:23 PM
Any ideas?
Hi @Tigger900
Do you have this?
@SlenderRobert it depends on where you are trying to download from. If you are trying to download recordings from your Q box then you need the multiscreen subscription to connect Sky go to your Q box if you are downloading through Sky go then you should be able to do this without the multiscreen subscription
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 14 Jul 2023 05:29 PM
Any ideas?
Hi @Tigger900
Do you have this?
@Tigger900 - try logging out of the Sky Go app & logging back in or even deleting the app completely & reinstalling it.@SlenderRobert it depends on where you are trying to download from. If you are trying to download recordings from your Q box then you need the multiscreen subscription to connect Sky go to your Q box if you are downloading through Sky go then you should be able to do this without the multiscreen subscription
Correct.
