Discussion topic: Download times
This message was authored by: Limpit86
Download times
Anyone else finding that downloads are taking about 3 years to complete recently. I'm only just exagerarinf aswell!
At first it was only on the Q box, with UHD but now it's even for HD on that and mini boxes.
My Internet (BT) is fine and I have tested that. I have the fastest speeds you can get. Why is this happening? Why does Netflix, Paramount, Disney all work fine.
Sky is just falling behind in everyway possible now and calling them takes even longer than download times since they moved it abroad.
Shouldn't even need to pay full whack when streaming on demand is part of the sales pitch
Re: Download times
Hi @Limpit86
You say Netflix etc work fine so is your issue with downloading and not streaming?
Avatar for Limpit86
Level 3 icon
Re: Download times
It may well be. But that is the only way to watch Sky wihh out it being live so surely it shouldn't be taking over an hour for one 25 minute HD episode of something .
It has definitely got slower and slower. The box I have is quite new too, a year old as it's HDR version. Does this happen for this withSky broadband? I'm guessing... No
Re: Download times
@Limpit86
What's wrong with simply recording a programme?
On a separate note, some call centre operations have moved abroad but Sky still maintain a UK Customer Service base. Your call is always transferred to the next available agent no matter where they are based.
Re: Download times
Hi @Limpit86
First check exactly what broadband speed your Main Q box is receiving.
You can do this in your Netflix App in the Main Q box.
Open Netflix and go to the left hand menu.
Scroll down to near the bottom of the menu and select Get Help.
On the next screen there is an option to Check your network.
Also you could try a Reset Settings in the main Q box hidden menu.
Avatar for Limpit86
Level 3 icon
Re: Download times
Concentrating on the recording reply...
Sometimes the programme has already been on, so unable to record.
Why should I/we have to do this? If that's the case, remove the on demand content and charge less
Re: Download times
@Limpit86 This is definitely something happening at your end. No change to download times here.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for Limpit86
Level 3 icon
Re: Download times
Spoke to Sky yesterday and they are sending a new box no questions asked. It is not an error with my Internet. I did a speed test on Netflix app via Sky box then on TV App and they were completely different. Anyone with similar issues give Sky a call
