Discussion topic: Download problem
This message was authored by: Miles
Download problem
Hi, when downloading a program to watch, it will partially download and then fail part way through. The program will play to the point it failed then jump out. Restarting the download sometimes works, but not always. Live shows record without a problem.
Re: Download problem
Hi @Miles
