Discussion topic: No satalite signal has a x but network connection has a tick next to it and to use service u need si
This message was authored by: Jane70
Message posted on 10 Nov 2023 05:36 PM
To use this service you need a signal is what it says on everything I try and do
Signal unlocked
Strength 0
Quality 0
LNB type Wideband
Pls help
Find out more
Message posted on 10 Nov 2023 05:57 PM
Re: No satalite signal has a x but network connection has a tick next to it and to use service u nee
Sky Q is a satellite television system and requires a signal from a satellite dish.
Was this box installed by Sky and been working previously at that address?
If so, you need to log a fault with sky and get the satellite dish and cabling checked.
