Discussion topic: Download problem
Message posted on 10 Nov 2023 05:21 PM
Download problem
Message posted on 10 Nov 2023 05:41 PM
Re: Download problem
@Miles wrote:
Hi, when downloading a program to watch, it will partially download and then fail part way through. The program will play to the point it failed then jump out. Restarting the download sometimes works, but not always. Live shows record without a problem.
Hi @Miles
