2
This discussion topic has been answered Discussion topic: Dont need UHD
This message was authored by: cliveneal
Dont need UHD
I have just upgraded to HD but I dont need UHD as I dont have cinema or sports channels.
This message was authored by: GD1 Answer
Re: Dont need UHD
@cliveneal  You would need to speak to Sky to remove that part of the subscription.  However as you've just upgraded it  may be part of the deal and removing it may affect the price you agreed.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Re: Dont need UHD
Avatar for cliveneal
Re: Dont need UHD
Thank you
Answered - Go to Answer
