Discussion topic: Do you pay a subscription for each mini box or does one subscription cover multiple mini boxes ?
Message posted on 28 Jan 2025 10:05 AM
I have a multi room subscription and currently one mini box. I'm looking at putting another in my daughters room will I need another subscription or will my current multi room subscription cover both boxes?
Message posted on 28 Jan 2025 10:07 AM
Re: Do you pay a subscription for each mini box or does one subscription cover multiple mini boxes ?
No
just the admin fee to get the extra box delivered
Message posted on 28 Jan 2025 11:34 AM
@NCK81
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Message posted on 28 Jan 2025 11:45 AM
Good reminder on the early 1TB box limitation.
