Discussion topic: Do I still need a sky dish
This message was authored by: JanG25
Hi I would like to know if I still need my sky dish. I am having some work on my house and it will need to be moved.  Thank you
Janet Gunner
Re: Do I still need a sky dish
@JanG25
You certainly do to stick with Sky Q. Contact sky to potentially move it (if a suitable alternative location is available). They normally charge about £65.,
Hi @JanG25   It is impossible to answer unless you tell us what Sky products you currently subscribe to.
Sky+, Sky+ HD and Sky Q are satellite television platforms and require a dish feed even when also connected to the internet.  Freesat reception also requires a dish.
Sky Glass and Sky Stream do not use a satellite dish.
my auntie has got the sky+ box at her static caravan but it works without a dish but she want to upgrade to sky Q can she have that without a dish as well
Sky+ and Sky Q needs a dish.  It can't be 'working' without one.
hi @Anonymous
A SKy + box needs a Satellite signal so is it possible that the Static Caravan is fed by a communal System if she doesn't have a personal dish ?
It would depend on the system as to whether it could be updated to work with SKY Q - SKY Q also needs a Satellite signal
This message was authored by: daveNOS
@Anonymous Im not sure how she is managing that as all Sky TV boxes(apart from Sky stream) require a connection to a satellite dish to receive any channels.
This message was authored by: profiler67
That is not true, Sky Q does not need a satellite dish it streams via WiFi
You're half right. It does stream over wifi, but for live TV and to record from live TV, a satellite dish is needed.
Without a satellite 'keep alive' signal the box stops working after a few days.
It very much won't work without a satellite dish.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
