Discussion topic: Sky Stream instead of Sky Q
Message posted on 06 Dec 2024 11:24 PM
I'm having huge problems with getting in touch.
I want to get rid of Sky Q and get Sky Stream but can't get a quote from anyone and the numbers I use don't seem to work.
What's the best way to do this so I can get a good price and move over.
Message posted on 06 Dec 2024 11:26 PM
Re: Sky Stream instead of Sky Q
You can call on 150 from a Sky Talk Line or Sky Mobile.
https://www.sky.com/help/home
Scroll down and click on ‘Need more help’ and it provides a 0333 number.
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. A some of the quieter times to ring are early morning or late evening.
Message posted on 07 Dec 2024 07:26 AM
@Smittymagic1986 Hopefully you've researched the big differences between the two systems.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
