Discussion topic: Distorted sound and vision
Message posted on 25 Sep 2026 04:29 PM
Distorted sound and vision on tv channels. No problems when streaming using apps
Message posted on 25 Sep 2026 04:32 PM
Re: Distorted sound and vision
@AllyC Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 25 Sep 2026 04:43 PM
I tried switching everything off etc. nonimprovement
Message posted on 25 Sep 2026 05:02 PM
@AllyC wrote:I tried switching everything off etc. nonimprovement
When you say a distorted picture, do you mean pixelated? That's usually a dish issue on Sky Q or HD+
You'd need to contact Sky for that or a local guy who can check the dish.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
