Discussion topic: Disney plus not working
This message was authored by: Lgil313
My disney plus app isn't working on sky. It used to work perfectly fine then all of a sudden a few weeks ago came up with- we are having a problem. Please exit and try again. Error code:1026- AUTH_SERVICE_INIT_FAILURE
We have tried closing the app, restarting the Box. Re-connecting the WiFi and nothing. Can you please advise?
Re: Disney plus not working
Hi @Lgil313
Have you tried refreshing the Apps in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
Avatar for Lgil313
Tried this. Still not working 😞
This message was authored by: OwenNew
Did you ever get this working? I am having the same issue.
This message was authored by: Jmoulding
I'm also getting this now, and I'm seeing a few other recent posts so hopefully sky, or one person at sky sees it is more than just one person lol
DRX890
DRX895
This message was authored by: Oj78
Did anyone get a fix for this?
This message was authored by: wheeeeeeeeeeeeee
For several weeks now,  Disney+ will just switch off leaving a black screen. The Sky box is still on, but has to be switched off and on again to start it working again,
It used to happen occasionally, but is happening much more often now,
It only happens with Disney+ , not with any other apps.
This message was authored by: urz2006
Having the same, anyone got any advice please? Engineer visit booked but sooooo frustrating, never had this before
Loads of people are having this issue - it's been happening for months.
This message was authored by: KGE
Is there a resolution to this issue?
This message was authored by: martianchild
Did this error ever get resolved? Error 1026?
have rest box and apps and router and connected via Ethernet etc etc etc...
