Discussion topic: Disney plus keeps coming up with loading ring, anyone else having this issue
This message was authored by: Tee2288
Disney plus keeps coming up with blue loading ring. Had a booster box put in and have had no issues til the last few weeks, anyone else had this problem?
Re: Disney plus keeps coming up with loading ring, anyone else having this issue
@Tee2288
Sky Q, Sky Glass or Stream ?
This message was authored by: leedsunited3
Yes, I'm having the same issue. It keeps refreshing and cutting out.
Same question as above then @leedsunited3 , on what device is this happening ?
Avatar for Tee2288
It's happening on streaming though a Q sky box (a new one) well the second new one iv had in a year. As the previous one had same issues
I wondered if it was a software or app update that was needed. So I tried that. Still happened tho
Avatar for Tee2288
Happening on a sky Q box
@Tee2288
I have moved your posts to the Sky Q forum as it isn't related to Sky Go where you had posted this.
There have been other reported problems with Disney+, more black screens than blue loading rings, but worth trying an apps refresh as there has been an update.
You can complete an apps refresh by pressing home > highlighting over 'settings' in the main menu without going into it > pressing 0, 0, 1 & Select > Go to Apps > complete an apps refresh.
It might take a while for the update to take effect.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
