4
This discussion topic has been answered Discussion topic: Sky q fully ethernet setup with sky broadband
This message was authored by: Gym10
Hi all,
I will keep this simple.
I have sky broadband FFTP 500mb
I have a sky q main box connected by ethernet to my sky hub.
I have four sky mini boxes all connected by ethernet.
This was all setup by sky engineer.
Aim: To use the mini boxes as hotspots!
I have noticed that on my main sky q box the wifi is switched off. (Engineer menu)
In addition two of four sky q mini boxes have the wifi switched off. (Enginner menu)
On this basis, as the main sky q box has the wifi switched off does this mean the minis will not be acting as hotspots even though the whole system is hard wired?
Even though the sky q minis are hard wired to ethernet do they need their individual wifi switched on for them to act as hotspots?
Any advice/confirmstion gratefull👍🏻
This message was authored by: stereohaven Answer
Re: Sky q fully ethernet setup with sky broadband
@Gym10 wrote:
I got my sky q box and all mini in 2022 so guess they are different than the 2016 version?
Nope, they are all still the same hardware.
If you want to make the most of that connection on other devices you should look at a more modern WiFi mesh.
Leave the Q mesh to just service TV across the system.
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Q Mini | SONOS Beam 2 | Apple TV 4K | EE Full Works FTTC
Yes they do: WiFi switched off is all WiFi.
Also note that the now antique (2016) Mini box WiFi can only sling a fraction of that kind of broadband speed: for a start they only have 100Mbs ethernet chips and will only broadcast 2.4Ghz.
Avatar for Gym10
Level 2 icon
Thank you.
So main box (hard wired) wifi switched on.
All my sky q mini (hard wired) wifi switched on.
Appreciate your help 👍🏻
Avatar for Gym10
Level 2 icon
My system is hardwired so i do not need the wifi for that purpose.
Just needed the wifi hotspots fir better wifi for phones and other devices 👍🏻
