This discussion topic is read only Discussion topic: Disney oops something went wrong
This message was authored by: Rachel0404
Hi
I got sky q installed again today however the Disney app will load but not okay.
the message 'oops something went wrong please try again later appears'
i have logged in and out etc to no avail
Locked
Re: Disney oops something went wrong
@Rachel0404 wrote:
Hi
@Rachel0404 Have you tried rebooting your box ie
unplug your box from the wall for 30 seconds
then
plug it back in again
and
follow the onscreen instructions
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Rachel0404
Hi yes I have unplugged everything and still not working
@Rachel0404 you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
It can take sometime for this to work
Locked
