3
This discussion topic is read only This discussion topic has been answered Discussion topic: Optimum HDMI to connect Sky Q to Sony OLED 4k TV.
This message was authored by: beejayf
Just connecting up new TV and wonder if any particular HDMI port on Sony OLED 4k TV will provide better functionality
This message was authored by: nigea99 Answer
Re: Optimum HDMI to connect Sky Q to Sony OLED 4k TV.
@beejayf wrote:
Thanks for great response - th emodel no is KE48A9 BU.
Hi @beejayf
It seems that the eARC port is number 3 not 2 as many TVs use (but it is labelled as eARC anyway)
I managed to get slightly confused by the manuals/guides - I suspect one I looked at was generic - it referred to a an 8K HDMI but the other implied all ports  were just 4K.
If you do have one labelled as 8K that is what I was referring to as HDMI 2.1 (i.e can be used but available for other higher spec'd equipement)
Oh and yes you need to set the port used to Enhanced
Locked
hi @beejayf I don't have a Sony but I suspect they are like most other OLED  TVs
Any HDMI port is likely to be OK but 2 things - generally most TVs use HDMI 2 for the ARC/eARC port so that is aimed at Sound Bars/ AV equipment rather than other inputs (but if you don't have any or plan to use it for Sound  out then  it can be used for SKY input)
Also if your TV has a limited number of HDMI 2.1 ports  -  that higher spec is not needed for SKY Q  as it will work in HDMI 2..0 (again can be used but the higher spec are  targetted at games machines etc)
Whichever HDMI Port you do use, make sure it set to Enhanced (I think that is the term for Sony's) to make sure it will work  for 4K/HDR
If you want more specific advice maybe quote the model
Avatar for beejayf
Hi @beejayf
Locked
