Discussion topic: Sky Q box not finding wifi
Message posted on 24 Nov 2021 01:22 PM
My sky q box said no connection to my Internet, so I reset the connection. Now when I search for networks to connect it says no WiFi networks found. I've reset Internet and sky box 7 times it still isn't working. Can't find number to phone sky anywhere.
Message posted on 24 Nov 2021 05:41 PM
Family member found the sky number, don't know where because I looked for ages 🤣 anyway got sorted over the phone!!
Message posted on 24 Nov 2021 01:28 PM
Re: Sky Q box not finding wifi
@Un1c0rnr43 wrote:My sky q box said no connection to my Internet, so I reset the connection. Now when I search for networks to connect it says no WiFi networks found. I've reset Internet and sky box 7 times it still isn't working. Can't find number to phone sky anywhere.
Do you have a Sky hub? If so try connecting using the WPS button?
Message posted on 24 Nov 2021 01:37 PM
My WiFi is not with sky
Message posted on 24 Nov 2021 02:09 PM
@Un1c0rnr43 Who is your Broadband provider ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 24 Nov 2021 02:54 PM
EE, my broadband isn't the issue as its working on my phone perfectly fine. Sky Q box won't pick up any WiFi networks at all
Message posted on 24 Nov 2021 05:45 PM
@Un1c0rnr43 glad you got it sorted can you tell us how it was sorted allo for future You can contact Sky by phone by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number
