1
This discussion topic has been answered Discussion topic: Dish movement
This message was authored by: Sue652
Dish movement
We had some work done yesterday and the knocked the dish with their portable scaffold knocking the dish out if alignment.   I need and engineer to realign please   it's a skyq box
Re: Dish movement
@Sue652
You'll need to call Sky to arrange that. You can't do it through the forum.
If you already have a Sky Mobile or a Sky Talk landline call free by dialling 150, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum.
Re: Dish movement
@Sue652
