Discussion topic: Discovery plus sign in
This message was authored by: ftballman
I'm having an issue signing in to discovery plus on my Q box. Just to set the scene my account is working fine and I can login to the app on another tv.
However on Q I get the discoveryplus link instruction and code but when I go to that page on my phone I get to login fine but am not prompted for the 6 digit code to link the sky box. I also cant find anywhere else within the site to link.
To add extra info I'm in Ireland.
Wondering what I'm missing.
This message was authored by: john_boy
Re: Discovery plus sign in
did you ever get an answer as I am having the same problem?
Avatar for ftballman
Level 5 icon
Long story short, no.
I have posted in a couple of other threads here where I suspect others are having the same or similar issues.
I am also in the middle of a days long back and forth with discovery plus support that doesn't seem to be going anywhere.
This message was authored by: jdemp
Same here  - when I sign in to discoveryplus.com/link and enter my id and password, I see the page where you can enter the link but it is immediately replace by the web page for the discoveryplus.com/gb site
The Discoveryplus support was useless - kept suggesting different devices, browsers but it is more than likely an error on their website
Level 5 icon
Wow that's how long ago I started the thread and yes a long running email back and forth with discovery's support went nowhere.
I am still unable to sign in on my sky box. Fortunately the app on my LG TV allows the alternative method of signing in with the remote but this won't suit everyone.
But yes my suspicion is that something is wrong with the website. In my own circumstances it looks like my discovery account has set me up as a UK user but I'm in Ireland and the site seems to keep redirecting.
That's probably it - I'm in Ireland too
Also, if I sign in to discoveryplus.com and try to look at my account - that doesn't work either
The problem seems to be the auto.discoveryplus.com which shows the activation screen fleetingly and then goes to the /gb page
Level 5 icon
Yes when contacting them there was a whole thing of explaining my issue, even taking video but no help. If you have the discovery plus app, you can access the account info in there and for me at least it says home country: UK.
This message was authored by: Mulett57
We had the same. We could only access Discovery+ by going through the access code login each time.
Today we had a broadband issue and solving that seems to have solved the Discovery+ issue too.
 1. Switch off the broadband router at plug
2. Switch off main Sky Box at plug
3. Switch off mini Sky Box at plug.
4. Wait a few minutes.
5. Switch router back on and wait for three green lights.
6. Switch main Sky Box on and go through restart process.
7. Do the same with mini Sky Box.
Once it was all up and running again, our login issue with Discovery+ appears fixed.
I hope this helps.
Paul.
This message was authored by: herbie2
I have tried to sign in for discoveryplus and it is not lettting in with user name and password
@herbie2 what username and password are you using
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
