Discussion topic: Screen goes blank to black then turns blue with error message technical fault try later
Message posted on 08 Jul 2025 08:19 PM
Sky is slow when forwarding and rewinding and some times it does not even stop when watching recording and this is for both the main and extra sky box
main issue is also changes channels screen goes black the. Blue an£ then get a message there is a technical fault try later.
i have turn off and turned on both boxes frm the main and still having issues
please advise
Message posted on 08 Jul 2025 08:22 PM
Re: Screen goes blank to black then turns blue with error message technical fault try later
please advise
Hi @Ranjana+b
Try a Reset Settings in the main Q box hidden menu.
