Discussion topic: Disconnecting sky whilst changing tv stands
This message was authored by Trixiegal This message was authored by: Trixiegal
I want to disconnect all the leads that go into my tv and sky box so as I can change my tv stand. I believe I was told not to unplug it at all. Would I have to then get someone out to reset it or if I make a note of which lead goes where will it just rectify itself?
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: Disconnecting sky whilst changing tv stands
You can safely power it down.  Unplug everything and put it back afterwards and power up again.
Trixiegal
Thank you. I know this may seem a stupid question but do you mean by power down just turning it off with the remote?🙈
Trixiegal
Oh and I'm talking sky Q here. 🤭
This message was authored by Padam_Padam This message was authored by: Padam_Padam
You can turn it all off at the wall and unplug it if it makes it easier to change the TV stand.
You won't lose anything and nothing will need to be reset when you plug it all back in. As you said, just make a careful note of which cable goes where (or take a photo of them all for reference too) and connect them back up later, then plug the Q box back in at the mains and turn it on. It'll take a minute or so to reboot after being turned off but after that you can turn it on and off as normal with the remote control.
This message was authored by Laing1 This message was authored by: Laing1
@Trixiegal probably the best thing to do is to take a picture of where the cables are before removing them then you can look at the picture for how to connect them again 😁
Trixiegal
Thank you all for your reassuring replies! 😅
