2
This discussion topic has been answered Discussion topic: Dimming pictures
This message was authored by: Jeanette16
Dimming pictures
Q box , when I switch my sky on the picture comes up then goes dim so it is not watchable, it is not the tv as I can still watch, I can still watch my Q mini upstairs, I have checked foe any loose cables, rebooted the box, change HMDI port, nothing seems to work
Re: Dimming pictures
Hi @Jeanette16
Hi @Jeanette16
Avatar for Jeanette16
Thank you, very much appreciated
