Discussion topic: Devlin
This message was authored by: Hello+Una
Devlin
Our sky box has cut out from 10 o clock this morning can you help please
Re: Devlin
@Hello+Una
More details on what's happening please?
Avatar for Hello+Una
Re: Devlin
We were watching tv and the sky just cut out, when we go menu we can't see the sky
Re: Devlin
@Hello+Una
Any error message on screen? Any lights displayed on the front of the box?
Re: Devlin
Tv just went black we can o my watch normal tv now
Re: Devlin
@Daniel0210 wrote:
@Hello+Una
Re: Devlin
Just one light
Re: Devlin
And what colour is it?
Re: Devlin
Green
Re: Devlin
@Hello+Una
So it has power. Have you tried a reboot of the box?
Reboot the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Re: Devlin
Ok try it now
Re: Devlin
Got it thank you so much very helpful
Re: Devlin
@Hello+Una
It's worth remembering that a reboot rectifies lots of little niggles and issues with the box.
