6
This discussion topic has been answered Discussion topic: Derek
This message was authored by: Deerek
Derek
I have 3 sky q mini boxes hard wired to a bt router. Working fine for mths then all of a sudden the 3 will not connect. I even tried WiFi & a factory reset on the mini boxes. Router is fine no issues & main box is fine. Help please
Avatar for Deerek
This message was authored by: Deerek Answer
Re: Derek
Eventually phoned sky to resolve issue. It turned out 1 of the mini boxes software was outdated. Now all mini boxes & main box software version updated everything works great all hardwired.
I have 1 mini box wifi but currently nt in use due to broken TV so when I buy a new TV fingers crossed it works. I wad told when I do connect the WiFi box sync with the closest sky box was button. I hope others can resolve issues with this thread.
Thanks everyone for your help
Re: Derek
Hi @Deerek
When all boxes are connected by Ethernet you can then switch off all Q box WiFi.
Start with main Q box and first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router. Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Repeat the network reset on any minis in the Mini Home menu with the Ethernet connected (one mini at a time).   Again do not do any WPS and just wait for it to connect.
Once it is connected go into the mini hidden menu (same procedure as above) and turn off both bands of WiFi. Confirm before exit.
Avatar for Deerek
Re: Derek
Hi Thank you. I checked the main box & the WiFi was already off. & the WiFi on the mini box was off. I did get a connection but in under 2 minutes it Freezes then says" connection issue betweenmini box & mainbox"
I give up maybe the main box is faulty as I can't even turn On the WiFi?
Re: Derek
Hi @Deerek Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with any Mini boxes?
Avatar for Deerek
Re: Derek
Hi I have tried that. I also did a factory reset on the  mini box. On all 3 mini boxes I get the same error message.  I have tested the ethernet cable on other equipment ie amazon fire box & ps5 & there was No issues so I'm guessing it must be a Main box fault not communicating with the mini boxes ??.
Avatar for Deerek
Re: Derek
Re: Derek
If they are connected over ethernet, do not use the WPS button.
edit: oh one of them is wifi only? Hmm ok well then you can't disable wifi on the one you connect it to. Hopefully that box will continue to work via ethernet and just hop to wifi for that link.
