Discussion topic: When watching sky Q I have message come up like technical fault with the channel like Itv1 I change
Message posted on 20 Nov 2023 10:46 AM
I have a technical fault with some of my channels on sky Q I be watching Itv1 and it would come up with that and some other channels as well I change the channel to bbc and then it's fine if I put it on Itv1+1 it works fine with no problems do I need a new sky Q box or is it find
Message posted on 20 Nov 2023 11:25 AM
Re: When watching sky Q I have message come up like technical fault with the channel like Itv1 I cha
You haven't said what you've tried already. Have you rebooted your main Sky Q box?
~ press the 🏠 button
Message posted on 20 Nov 2023 11:50 AM
Yes I've done all that and it still mess up had someone out from my housing they changed the cables in the loft this morning and it working fine now not sure how long it will last
Message posted on 20 Nov 2023 11:52 AM
Are you on a communal satellite dish or do you have your own?
Message posted on 20 Nov 2023 11:56 AM
Yes on a shared dish in a block of flats
Message posted on 20 Nov 2023 11:59 AM
Then you'll need to report Sky Q faults to your landlord or management company and not Sky directly. They are responsible for organising any maintenance/repairs.
Message posted on 22 Nov 2023 12:07 AM
Ok thank you for the advice
