Discussion topic: Delays/freezing not forwarding/rewinding
Message posted on 30 May 2024 03:00 PM
Q box says technical fault, once programme is paused it will not play again, when forward/rewind is pressed picture freezes, the rewind/forward line at the bottom of screen keeps jumping around and when changing channel there is a long delay 5-10secs. Also when Q box is turned off, picture goes off but sound stays for a few seconds. I have rebooted 2-3 times but still the same, also mini box problem
Message posted on 30 May 2024 04:11 PM
Re: Delays/freezing not forwarding/rewinding
Hi @TARIQ13
Try a Reset Settings in the main Q box hidden menu.
Message posted on 31 May 2024 05:15 PM
Hi, I have the same problem and I have tried to reboot as you suggested but channels still very slow to respond and app images etc are missing. Is there anything else to try ?
