Discussion topic: Defective equipment
Message posted on 10 Jul 2023 04:26 PM
Defective equipment
Main remote control play pause forward and rewind not working, also an additional box won't work (it hasn't been used for a few months) also when does my deal run out ?
Message posted on 10 Jul 2023 06:19 PM
Re: Defective equipment
@Sharpo7 for your remote problem
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
for your mini box problem tryrebooting your main Q box ie
then
rebooting your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 10 Jul 2023 06:37 PM - last edited: 10 Jul 2023 06:38 PM
Hi @Sharpo7
If you look at your subscriptions (Change products) in the My Sky App or Website, the Contract end date is clearly shown against each subscription currently with a discount.
