This discussion topic has been answered Discussion topic: Deborah
Message posted on 28 Sep 2023 09:51 PM
None of the Appa will load. I was trying to load BBC iPlayer how ever have also tried Netflix and ITV X and none will load.
I have tried to refresh the Apps in the settings menu but this made no difference
can anyone advise why I should do to get the Apps working. I have not changed the TV or any settings and last time I tried the Apps we're working fine
Message posted on 01 Oct 2023 11:19 PM
Thanks for the advice - the soft re-sent worked and I am now able to access all Apps
Message posted on 28 Sep 2023 10:04 PM
Re: Deborah
Have you tried a simple reboot
Failing this
