3
This discussion topic has been answered Discussion topic: Cracked/broken sky Q mini box
This message was authored by: juliealexred
Will Sky provide me with a new mini box for free, if mine is damaged and no longer works?
If they will charge me, any idea how much it would be?
or can I just buy one from eBay, will it work with the rest of my boxes?
This message was authored by: Chodley Answer
Re: Cracked/broken sky Q mini box
You can't buy one. They're property of Sky. Give them a call. Clearly it's been damaged rather than going wrong but they might not charge you.
This message was authored by: best+of+the+best
@juliealexred cracked and broken is not normal wear and tear so you will have to speak to Sky about the replacement costs
If your Sky Q mini box is over heating develops a fault then Sky will replace the unit but you will still need to phone Sky to report this  for a replacement unit to be sent out.
Sky Q mini boxes are loaned to you so buying one off ebay is a no go as they are classed as stolen and won't work
Avatar for juliealexred
Level 0 icon
Thank you for all your help!
Answered - Go to Answer
