8
This discussion topic has been answered Discussion topic: Court TV not working
This message was authored by: CLD2
Hi all
my Court TV isn't working, it's either a very broken signal or no signal at all.  All other channels are working fine and several re-boots haven't helped. Any ideas?
Re: Court TV not working
@CLD2
No signal and no satellite signal are different .
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
@CLD2
Are you seeing a no satellite signal error message?
Avatar for CLD2
Yes but all other channels are ok
@CLD2
Avatar for CLD2
Thanks Daniel
went through that and have booked an engineer
When you have problems with Court TV, see if other channels on the same frequency are also affected. They are mainly shopping channels including Best Direct (669), JewelleryMaker (674), TV Warehouse (673). This will confirm if it's a dish issue and not just a temporary problem with Court TV.
Avatar for CLD2
That's really helpful thank you. Yep they're all the same, have booked an engineer to come out this afternoon
@CLD2
You're very fortunate to get an engineer visit the same day.
Avatar for CLD2
I was a bit shocked tbf 🤣
thanks for your help
Answered - Go to Answer
