8
This discussion topic has been answered Discussion topic: Control Samsung hw-t400
This message was authored by: Iggy1977
I have a Samsung HW-T400 soundbar which I used to be able to control with my Sky Q remote. The remote has decided it won't control the volume on the soundbar, so went to settings-setup-remote control.  Selected Sky Q and control speaker. Picked Samsung and started working through the codes.  This time none have worked?  Anyone know the code?
Avatar for Iggy1977
This message was authored by: Iggy1977 Answer
Re: Control Samsung hw-t400
Sorry, updated the firmware.
I did all this with the old controller still in use.  I thought no the key solution was the new Sky Q remote which had the voice control button.
This message was authored by: bob1234
@Iggy1977If you have a HDMI arc socket on your TV and connect this to your soundbar HDMI input (if it has one), the TV should control the soundbar volume so long as your Sky remote will control the TV volume without any codes needed.
Avatar for Iggy1977
Hi Bob.  Thanks but no arc on the tv ☹️
This message was authored by: Brighty22
Did you find a fix for this? Mine has done the same for no reason and also cannot fix it! Thanks
Avatar for Iggy1977
Hi
i had to update the Sky Q box, and my tv.  Also had to get a new Sky Q remote from Sky. I chatted to them online and they sent a replacement which was a voice control one.
then re-setup everything again and the Sky Q box recognised the soundbar.
Good news. Do you mean you updated sky Q box and tv firmware? Or new box & TV? Cheers
Avatar for Iggy1977
Avatar for Iggy1977
Ignore previous reply.  Trying to reply and multitask.
I did all this with the old controller still in use.  I think the key solution was the new Sky Q remote which had the voice control button
Ok cool, will try both! Cheers
Answered - Go to Answer
