Discussion topic: Constantly getting HDCP Error when starting Sky Q
Message posted on 20 Oct 2024 12:07 PM
When I start SKY Q, I sometimes see the error "This screen does not support HDCP. Try reconnecting your HDMI cable, or use a different screen". My TV is a Sony KD 49XF7003. This only occurs sometimes when taking SKY Q out of standby for the first time. If I switch the TV off, take Sky Q back to standby and then start again, I can get it to work normally. I've had this issue ever since I've had SKY Q and it is frankly getting on my nerves now. A premium product like SKY Q shouldn't do this. I have no problems with much older TVs around the house when using SKY Q on Multiroom.
I have tried many different HDMI cables, including premium quality ones, however, it makes no difference. I have also tried completely powering down and restarting the box. I don't get this issue at all when I am not using SKY Q on the TV, i.e. using the TV's built-in apps. It is getting to the point where I am considering dumping SKY altogether as it’s so infuriating to have this issue on the main TV in the house, so some help would be appreciated. Thanks.
Message posted on 20 Oct 2024 01:42 PM - last edited: 20 Oct 2024 01:43 PM
Re: Constantly getting HDCP Error when starting Sky Q
On-set apps don't use HDCP at all: that's a protection technology specific to HDMI cable 'handshake' between what the specification calls a 'source' and a 'sink' device.
Message posted on 20 Oct 2024 01:49 PM
Updated the firmware on the TV?
It may be intrinsic with the TV of course - it seems the HDCP handshake has timing issues.
Message posted on 20 Oct 2024 02:54 PM - last edited: 20 Oct 2024 02:55 PM
Tried a mini on that Sony to see if the same thing happens?
Is the Q connected direct to the TV or is there a sound device between?
Message posted on 20 Oct 2024 03:12 PM
Yes, tried that and the TV is up to date.
Message posted on 20 Oct 2024 03:31 PM
Yes the Sky Q box is connected direct to the TV not via sound bar/system. The Sony TV has had its firmware updated - happens automatically. I tried a new 1 meter ultra high speed 8k hdmi 2.1 cable but no difference. Also tried a complete power off of both TV and sky box, left for 5 mins and then started again. No joy, though have just done this once more to be sure. Not tried connecting mini to the Sony TV but will try - not sure what this will prove though. All other suggestions appreciated. Thanks.
Message posted on 20 Oct 2024 03:39 PM
@TheFuryZone wrote:Not tried connecting mini to the Sony TV but will try - not sure what this will prove though
That perhaps the main box does have a 'fault'. (Convincing Sky to replace it may be a challenge and you will lose all recordings)
Message posted on 20 Oct 2024 06:04 PM
@TheFuryZone wrote:Yes the Sky Q box is connected direct to the TV not via sound bar/system. The Sony TV has had its firmware updated - happens automatically. I tried a new 1 meter ultra high speed 8k hdmi 2.1 cable but no difference. Also tried a complete power off of both TV and sky box, left for 5 mins and then started again. No joy, though have just done this once more to be sure. Not tried connecting mini to the Sony TV but will try - not sure what this will prove though. All other suggestions appreciated. Thanks.
Might suggest, if it also happens, that there's an issue with the TV. Not conclusively though.
Message posted on 20 Oct 2024 06:55 PM - last edited: 20 Oct 2024 06:57 PM
For what it's worth, I'd note that's a television model from 2018, but supposedly specified for HDCP2.3
