Discussion topic: sky q multiroom
Message posted on 20 Oct 2024 06:59 PM
sky q multiroom
I thought that I could be watching a programme in the room with the q box in, press pause, and pick up from where I left off in a different room with q mini.
Not been able to figure this out though.
Am I mistaken?
Message posted on 20 Oct 2024 07:04 PM - last edited: 20 Oct 2024 07:05 PM
Re: sky q multiroom
Am I mistaken?
hi @sarsons
Not quite as 'fluid' as the original SKY marketing made it look.
It only works with recordings so if it is live TV you need to set it to record and then make sure you move away from that channel (or start watching the recording and press pause)
Edit : BTW the pause on a live channel only pauses the live channel 'buffer' that is different for each box
