Discussion topic: Constant freezing and buffering watching Disney
This message was authored by TripleTea This message was authored by: TripleTea
Hi, I have a sky box in one room and mini box in ther room and I am getting constant bufffering issues watching Disney on the mini box is fine on the main box. WiFi connection is sound and I have fibre broadband. Why. Is it only Disney? All others are good.
This message was authored by ThePope27 This message was authored by: ThePope27
Re: Constant freezing and buffering watching Disney
Hi @TripleTea
Have you tried refreshing the Apps in the Hidden menu. To enter hidden menu press Home and navigate down to Settings but do not select Settings. With Settings highlighted press 0 0 1 Select.then highlight Refresh all Apps on this box.
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
This message was authored by lkmnlkmlkm This message was authored by: lkmnlkmlkm
I get the same through the main box. Only happens with Disney Plus through Sky.  Becoming a major problem.
It's a smart tv, and have launched directly via the tv and it's fine.
This message was authored by Wilf-66 This message was authored by: Wilf-66
It only happens with some streams on D+, mainly Rivals..
This message was authored by DaleGreen This message was authored by: DaleGreen
I'm also getting this. Only Disney+.
This message was authored by Dillon1 This message was authored by: Dillon1
Same here sky q box the Disney app laggy and freezing internet is hard wired 1 gb up + down internet is fine the sky q box is the problem it's been a few years we need a more capable sky q box the hardware is getting old now.
This message was authored by John422 This message was authored by: John422
I have tried refreshing the apps. Still keeps happening on Disney + on the main box
It's the hardware it's getting old now and can't keep up with modern streaming our internet is fine it's the sky q box hardware they need to update the sky q boxes but they won't.  now it seems they want everyone to get sky stream which is inferior hardware but it's easy for sky to maintain vs satellite
This message was authored by JonathanMad This message was authored by: JonathanMad
I have had to give up with Disney through Sky Q as it constantly crashes. Now I  use my Apple TV box.
Same here I use fire tv cube the app system on the sky q is terrible
This message was authored by Kickboxingboy This message was authored by: Kickboxingboy
When are sky going to fix this Disney plus issue ?
sky q , hard wired Ethernet , gigabit switch and gigabit fibre.
Disney is the only app with issue and it's been over a year. It's unwatchable .
please sky sort this out!!!!!
They simply not bothered at all they want us all to use the inferior sky stream which is basically a fire stick if only they would release an updated sky q box all the issues would be solved but they won't because it's cheaper to maintain stream I think there is only 10 years left on the sky q satellite service before we are forced into stream.
This message was authored by Laing1 This message was authored by: Laing1
@Dillon1 there will be no new Q box
Skys contract with SES who own the satellites runs out in 2029 and the satellites that Sky use will run out of positioning fuel in around 2030 so will be unuseable by that date so its likely that Sky Q and satelitte TV from Sky will be gone by 2030
So less time then I originally thought shame looks like sky plans on switching everyone to stream will be sooner rather then later.
This message was authored by Kriya3000 This message was authored by: Kriya3000
Sky Q is terrible with Disney+ and YouTube.  Constant buffering.  It used to work successfully a couple of years ago.  My BB speed is now 3 times faster.  The other day it was so diabolical, it was like having dial up Internet via the telephone from the last century.  I don't want to have Sky Stream and constant adverts or pay to remove adverts.  Please fix our beloved Sky Q.  I like to record stuff and have a box.  Thanks.
