Discussion topic: Connectivity
Message posted on 01 Sep 2023 09:02 PM
Connectivity
Hi I've just changed Internet provider and updated the network settings on my sky q box but after about an hour it loses connection. When I go back into settings it's trying to reconnect to the old WiFi. Any ideas how I sort this so I have constant connection on my new WiFi provider
Message posted on 01 Sep 2023 09:19 PM
Re: Connectivity
Hi @Amer
Assume that you were previously on Sky Broadband and are now on 3rd party broadband.
Also assume that you are carrying out a Network reset on your Q box using SSID and password.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band..
If you are looking in the Q box settings and seeing a Sky ID then this will be the Q WiFi mesh generated by the Q box. (Not the WiFi it is connecting to)
Message posted on 01 Sep 2023 11:22 PM
Re: Connectivity
I've was with a 3rd party previously and now again moved to another 3rd party I've entered the new WiFi details but after a while it again try to connect to the old connection. I'm not sure how to get the sky q box to forget the old settings
